Beyond™ Drive™: Wear Detection Made Easy
07.14.2015
Kennametal’s Beyond™ Drive™, now available in NOVO, is the solution for those looking for increased metal removal rates, longer tool life, versatility and improved wear detection. Beyond Drive is a technology for advanced surface treatment and wear detection that increases productivity and process safety. Its post-coat treatment reduces stress and improves coating adhesion and allows for better toughness, wear resistance and wear detection. For a limited time, Beyond Drive is available for a free trial – simply fill out this brief form to obtain your free test insert.
Benefits of Beyond Drive
Beyond Drive from Kennametal (a member of Partners in THINC) provides a long list of benefits:
• Higher productivity and profitability – up to 30% higher
• Lower cutting forces – increase speeds and reduce cycle time
• Extended tool life
• Predictable tool life/uniform wear
• Resists chip flow damage
• Consistent surface finish
• Products can be applied across a wide range of applications
• Use it in low speed to high speed applications
• For finish to rough turning of steel, cast iron, stainless steel, and high-temp alloy turning
See For Yourself
For more information and a video demonstration, visit the Beyond Drive web page. For the ultimate demonstration, order your free insert and give it a try in your shop (limited time offer).
