Blum-Novotest’s TC64-RG Roughness Gauge
03.17.2016
Blum-Novotest’s TC64-RG Roughness Gauge represents a quantum leap in the field of machine-integrated quality monitoring. In the past, a reliable method of surface finish analysis could only be performed post-machining, which meant the part had to be removed for analysis. Then, if during inspection rework was deemed necessary, the part would either be hand finished or returned to the machine for machining, during which resetting the part in its original orientation could be difficult. If not reset correctly, new defects could be introduced into the surface finish.
Gauge On the Machine
The TC64-RG was developed for manufacturers who want to check part surface finish before removing the part from their CNC machining center. With a special stylus and the gauge’s integrated Digilog-technology, a technology that allows analog scanning of the part, the gauge can accurately determine a part’s surface “roughness” with the part in its original orientation, thereby eliminating resetting of the part. Surface data is recorded from the scan and transmitted wirelessly to Blum’s interface, which then compares the data to recorded data of a part with optimal surface finish. Any spike in the data can be set to alert the operator automatically.
Integrated Process Control
This technology provides a means of integrated process control for manufacturers that must hold a specified grade of surface finish. Previously, there was no real automated method of checking surface finish on the machining center. Now with the TC64-RG, the operator can correct any issues before the process gets out of control.
More: Read the full article on the Manufacturing Engineering website.
Visit Blum-Novotest at IMTS 2016, Booth E-5527.
