O.D. to I.D. Clamping Without Changing the Clamping Device
Did you know that it’s possible to change over from O.D. clamping to perfect I.D. clamping, without changing the clamping device? No problem with the MANDO Adapt from HAINBUCH, a member of Partners in THINC. Simply place the mandrel in the mounted clamping device, tighten three screws, and lock the mandrel in the clamping device.
Significant Time Saver
In this process the mandrel engages in the coupling of the clamping device via a sophisticated mechanism, where otherwise the clamping head engages. MANDO Adapt enables extreme rigidity and precision. For rotating products, concentricity of 0.005 mm between chuck taper and mandrel taper can be achieved. For stationary clamping devices repeatability of 0.003 mm is possible. This can all be accomplished without making adjustments. MANDO Adapt is available in three versions:
T211: Clamping with pull-back effect and with draw bolt
T212: Clamping with pull-back effect and without draw bolt
T812: Clamping without pull-back effect and without draw bolt
MANDO Adapt: Key Advantages
  • Extremely fast conversion without disassembling the base clamping device [2 minutes]
  • Vibration dampening due to vulcanized segmented clamping bushings
  • Extremely high clamping force even at the smallest clamping Ø
  • Large clamping range due to vulcanized clamping elements
  • Standard end-stop for machining to size
About HAINBUCH America
Founded in 1951, HAINBUCH has a long history of innovation beginning with the original quick change collet system, first patented in the USA in 1980. Today the company boasts over 150 patents worldwide and continues to revolutionize the field of precise, adaptable and quick change collet chucks. HAINBUCH America traces its beginnings to 1997 when the parent company opened its first sales office in suburban Milwaukee, Wisconsin. The company continues to develop a reputation as an innovator in quick change OD and ID workholding solutions for the rapidly growing CNC lathe and CNC milling machine markets.
