Koma Precision Introduces New Line of Alberti Angle Heads
Koma Precision, Inc. introduces the new TH Line angle heads from Alberti – a manufacturer of high quality state-of-the-art angle heads. For over 35 years, Alberti has been providing the most innovative range of products that are extremely reliable and enable manufacturing in strict tolerances. Koma Precision is pleased to offer these high quality angle heads to Okuma users as a member of Partners in THINC.
Ideal for Aerospace
The TH line of angle heads is targeted for aerospace parts manufacturing. The angle head casting is made from GS 600 stabilized spheroidal cast iron that enables the tool to perform optimally. The GS 600 alloy provides increased thermal stability and rigidity compared to materials such as steel and aluminum. The most important feature of this line is that the TH Series angle heads can be run with or without coolant, without making any changes to the installation. The offset design of the TH Series heads enables customers to use extended length tools.
Built for High Performance
All Alberti angle head spindles with arbor are manufactured from one solid piece of hardened steel that increases resistance to bending stress by 25%. This also enables the tools to reach higher RPM without vibrations, thus resulting in higher speed and precision. The unique angular contact bearings ensure perfect concentricity and stability required to achieve higher performance of machining operations. The superior mechanical seals and gears are researched and developed at the Alberti Engineering and Technology Center. Alberti believes in continuous improvement and has been reinvesting a significant portion of their total turnover in research and development.
About Koma Precision, Inc.
Since 1982, Koma Precision, Inc. has served machine tool builders and end users by supplying the world’s highest quality attachments and accessories through a nationwide distributor network. Their 25,000 square foot headquarters located in East Windsor, Connecticut, USA houses sales, marketing, application engineering, product and parts inventory, repair and rebuilding service support operations. Koma Precision, Inc. remains dedicated to exceeding customer expectations and getting the job done right.
