Quick Change Chuck Reduces Setup and Changeover
07.29.2012
A MULTUS B300 multitasking horizontal lathe is a workhorse of a machine, traditionally found in high production facilities. However, the addition of a Quick Change Chuck from Schunk turns this high production machine tool into a job shop machine with a quick turn of a wrench.
David Fischer, Okuma Product Specialist demonstrates how the Multus 300 can run; a small manifold utilizing a tombstone; a long shaft part utilizing the NC tailstock; and an aluminum plug, all in minimal time and with minimal effort. The Schunk Quick Change Jaw System employs exchangeable inserts that are released with a turn of a “key” tool allowing for varied jaw sizes and clamping pressures.
To further increase the effectiveness and efficiency of the machine Sandvik Coromant multi-tooling is used to help increase the number of tools without increasing tool index time.
Reduce setup and changeover time, improving productivity.
