SCHUNK Introduces New TENDO Platinum Toolholder
SCHUNK, a member of Partners in THINC, introduces the new TENDO Platinum toolholder, with advanced technology that increases durability and precision for almost any milling, drilling, and reaming application.
TENDO Platinum enhances brazing technology by using a unique brazing and hardening process in the same cycle, allowing for the most rigid and durable tool clamping available. The TENDO Platinum is balanced to G2.5 at 25,000 RPM. With excellent vibration dampening and precise run out accuracy of less than 0.003 mm (0.0001’’) at 2.5 x clamping diameter, the TENDO Platinum protects the CNC machine spindle and the cutting tool from damages including wear and tear. The TENDO Platinum is available in three lengths with two precision-ground taper sizes: CAT40 – 2.5’’, 4’’, 6’’ / CAT50 – 81mm, 4’’, 6’’. In addition, SCHUNK offers direct clamping in both metric and inch sizes to ensure optimum accuracy and vibration dampening.
The TENDO Platinum is manufactured from the highest-grade tool steel and thru hardened to ensure a long tool life. For more information on SCHUNK visit http:/www.okuma.com/schunk.
