Aerospace Machining: Blades and Blisks
12.10.2015
In a recent “Tech Talk" video ISCAR shares some innovative suggestions for efficient aerospace machining, especially suited for manufacturers of challenging jet engine components such as blades and blisks. Designed for high-speed machining, ISCAR’s solid carbide MULTI-MASTER end mills feature threaded, quick change, interchangeable cutting heads. The MULTI-MASTER system requires minimal setup time and offers more than 15,000 standard head extension combinations. ISCAR provides premium solid carbide multi-flute end mills for roughing, semi-finishing and finishing operations. The solid carbide and MULTI-MASTER end mills are widely accepted as high-performance tools for milling jet engine blades and bladed disks made of titanium and high-temperature alloys.
Reduced Cost Per Unit in Aerospace Machining
The video demonstrates the types of end mills that are best suited for roughing, semi-finishing and finishing operations in the aerospace machining process. The development of a wide range of highly-efficient ISCAR cutting tools with new carbide grades and innovative geometries has enabled many global manufacturers of jet engine blades and blisks to achieve considerably reduced cost per unit (CPU).
Watch ISCAR’s video to see the complete demonstration.
