OEM Spindle Support from Okuma
02.20.2019
We fully understand the importance of minimizing downtime and keeping your machine tool spindles turning. When a catastrophic failure occurs, turn to the original equipment manufacturer (OEM) to help maximize utilization of your Okuma machine tool and enhance your customer experience.
Benefits of Working with the OEM
Okuma America has an enormous amount of spindle inventory, which provides us the ability to ship a replacement spindle before the failed unit has even been taken out of the machine. This means, in most cases, your machine is back online within 24 hours and core return can then take place. Depending on time sensitivity, Okuma also offers a repair and return program. Okuma assures a premier product, built by trained spindle technicians, that offers:
- Shortest lead time
- Complete failure analysis
- OEM certified parts
- OEM updates
- OEM specifications
- Engineering support from Okuma Japan
- Industry-leading warranty
- Static and dynamically run tested
- Full vibration analysis
Okuma America can also assist you with your ATC Cam Box and DCMC Attachment Unit needs. Contact your local Okuma distributor to assist with all your mechanical needs.
Thanks to Mike Hampton, Business Development Specialist – Aftermarket Parts, Okuma America Corporation, for providing this article.
