Turn-Cut Enables Turning on Horizontal Machining Centers
07.10.2013
Executive Summary
Turn-Cut is a programming option available on Okuma horizontal machining centers that allows the machine to create bores and diameters that include circular and/or angular features. This enables users to turn features on large, unbalanced parts on the same platform where standard CNC machining functions are performed. Turn-Cut eliminates the need to purchase special-purpose machines, tooling, fixtures or add-on components.
Turn-Cut operates by leveraging Okuma’s philosophy of manufacturing both control and machine, a mechatronics approach which provides a synergistic system that delivers greater reliability and optimized performance. It uses standard tooling, which, in most cases, saves on tooling costs. Turn-Cut works without additional motors, servos, and heavy attachments, and integrates with tooling already developed and readily available. Turn-Cut enhances the use of the machine without adding components or weight that may restrict its use during normal CNC machining operations.
Turn-Cut does not affect the performance or longevity of the machine, and in fact enhances performance with the addition of Abso-scales and chilled ballscrews. When heavy milling is required, the Okuma horizontal machining center equipped with Turn-Cut is still as capable as ever. Most importantly, Turn-Cut allows for processing work without the need to use a secondary machine for a turning application. Parts such as valves, pipe or manifold-type parts are ideal candidates for Turn-Cut.
DOWNLOAD THIS WHITE PAPER
This white paper is also available as a free downloadable PDF. Or, you can continue reading it below.
WHAT IS TURN-CUT?
Turn-Cut is a programming option that enables a horizontal machining center to create surfaces that taper, arc or have any combination of varying diameter shapes along the Z-axis of a work piece (see Figure 1). The surfaces created by Turn-Cut can be either on the outside or inside diameter of the machined part. Turn-Cut can operate using standard tooling and minimal fixturing.
![Turncut img1](https://d30jruhmdicmo0.cloudfront.net/general/turncut_img1.png)
![Turncut img2 ff](https://d30jruhmdicmo0.cloudfront.net/general/_zPattern/turncut_img2_ff.png)
Turn-Cut is used in applications that would traditionally use a CNC lathe to turn a feature (see Figure 2). In some cases, the part configuration (size, shape, weight) prohibits it from being set up on a lathe. With Turn-Cut, the part is stationary as the Turn-Cut programming creates the tool path. Enables Lathe Operations on a Horizontal Machining Center Lathe operation Turn-Cut operation.
Turn-Cut synchronizes the X & Y circular motion with the spindle angle to ensure the tool edge maintains its programmed path at all times. Turn-Cut is turned on by a G-code in the program and follows standard programming convention to describe the desired path.
ENEFITS OF TURN-CUT
- Turn-Cut provides process optimization capabilities without a large investment in specialized tooling, attachments, fixturing or even a specialized machine tool. Turn-Cut can be installed on Okuma horizontal machining centers while maintaining the original performance of the machine. In nearly all cases, the additional options of the Turn-Cut package will make the machine perform more consistently, even in applications not requiring Turn-Cut.
- Turn-Cut simplifies fixturing and reduces set up time as well. Standard fixturing can be used with Turn-Cut instead of complex fixtures typically required to orient the part.
- Setup time is reduced since the part does not have to be moved to another machine to perform the operation handled by Turn-Cut.
- Expensive index chucks are no longer needed for manufacturing of small valves or Ts. Turn-Cut on a horizontal machining center can perform the same operation with less fixturing investment.
- Complex heads or specialized tooling used to control tool path are not required with Turn-Cut. The use of these types of attachments typically adds complexity to the setup and also adds extra weight past the spindle taper.
THEORY OF OPERATION
The Turn-Cut function performs cutting on a horizontal machining center by synchronizing the circular motion of the feed axis with the spindle's turning angle (tool tip position control). (See Figure 3).
- The tool turns by synchronizing high-speed circular motion on the feed axes X and Y with the turning angle of the spindle. The position of the turning tool tip is synchronously controlled so it is kept perpendicular to the workpiece face.
- The cross section configuration is commanded with Z-X as in a turning program. The X-axis is commanded with the radius of X-Y continuous circular motion.
The above features enable turning of cylindrical workpieces and inside/outside diameter tapers on the horizontal machining center. The program can be commanded in the very same manner as turning on a CNC lathe according to a turning program (Z-X).
With the center of the axes (0, 0) as the origin of the workpiece coordinate system:
- Continuous circular motion can be commanded in place of the spindle; and
- The feed axis dimension (Z) and the radius (X) can be commanded.
![turning on a horizontal machining center diagram](https://d30jruhmdicmo0.cloudfront.net/general/turncut_img4.png)
TURN-CUT ADVANTAGES
There are technologies on the market designed to accomplish these tasks, including U axis heads, externally driven U axis heads, index chucks and special purpose machines. Following are the advantages of using Turn-Cut as a more efficient alternative to these technologies.
- Use of a single tool for multiple diameters
- Process intensive machining in one setup
- Fewer tools, less set up required
- Provides desired machining finish in seal surfaces
- Can handle unbalanced workpieces
- Maintains the machine’s standard functions
- Works with readily available tooling components
- Does not add weight, length or heat to the spindle in order to operate
- Does not require special fixturing
- Does not require special programming
- Can also be used for threading
STREAMLINE COSTS AND OPERATIONS
Turn-Cut minimizes capital equipment costs, eliminates the need for additional floor space in the shop, provides a robust platform for CNC machining, simplifies fixturing and reduces set up time. This creates efficiencies that maximize profitability.
For more information about Turn-Cut and the products on which it is available, check with your local Okuma Distributor, or contact us.
To see Okuma's Turn-Cut function in action, watch the video:
